Activity › Forums › Apple Final Cut Pro Legacy › Multi-clip question
  • Multi-clip question
    Posted by Daniel Schultz on March 9, 2010 at 8:16 pm
    I did some cuts on a multi-clip in the timeline…used the razor blade and cut pieces out to do some rough editing. Now I seem have lost the ability to see both camera angles in the viewer.
    Am I doing something wrong? Is there a quick/easy way to get the multiple-camera-angles back?
    Thanks in advance.
    Dan S.
    Daniel Schultz replied 16 years, 6 months ago 3 Members · 5 Replies
  • Michael Sacci
    March 9, 2010 at 9:20 pm
    Do you have your sync set to “open”?
  • Daniel Schultz
    March 9, 2010 at 9:23 pm
    Yes. I double-clicked on the clip in the timeline to bring it into the viewer. Then select “open.” I click back to the timline.
    Then both angles DO show up in the viewer. But then when play the clip, as soon as the clip is playing, I lose both angles in the viewer and it goes back to showing only the one angle.
    I’m probably doing something stupid, right?
    Dan S.
  • Michael Sacci
    March 9, 2010 at 10:58 pm
    Sounds like the clips got rendered. Click the green visibility button on the left off and on that that clears the render and it should keep the 2 up in the viewer.
    I always have to remember to turn off auto-render in prefs when working on multi-cam.
  • John Pale
    March 10, 2010 at 6:45 am
    [Daniel Schultz] “I double-clicked on the clip in the timeline to bring it into the viewer”
    Dont do that. Just park your playhead over the clip, then select “open” in the viewer.
  • Daniel Schultz
    March 15, 2010 at 9:43 am
    Worked like a charm.
    Thanks, Michael!
    Dan S.
