Multi Clip offline solution
Hi all,
I’m working for a performing arts organization where we record performances with up to 12 angles of ISO to a SAN using PictureReady. Last season we used DVC ProHD 1080i as our recording format, then put those quicktime files in a multi_clip and used them for the cut.This coming season we are switching to a 23.98 timebase for our capture and we are thinking about using ProRes as our acquisition format. Since it isn’t possible to playback more than 4 streams of ProRes at a time we need to develop a offline workflow of some sort.
I am currently leaning toward DVC_Pro_HD 720P 23.98 as our offline codec because what ever I offline use in needs to be HD for us to check focus. Unfortunately this does save us a lot of space and is going to require us to dump our source files to LTO as soon as our offline clips are rendered causing quite a bit of data management.
My question is does anybody have any suggestions for a better workflow or offline codec?Thanks
–Trevor
data slave and ass editor
