Activity Forums Apple Final Cut Pro Legacy Multi clip and color correction
  • Multi clip and color correction
    Posted by Gary Malec on May 27, 2009 at 5:47 pm
    I just got done cutting a 1 hour multi clip and color corrected the original clips afterwards. The color correction didnt follow into the multi clip sequence. I haven’t used the multi clip function before and am wondering if there is a way to carry my color correction over without having to copy and paste attributes to every single cut. Any help would be greatly appreciated!
    Karl Richter replied 17 years, 3 months ago 2 Members · 1 Reply
  • Karl Richter
    May 27, 2009 at 7:41 pm
    That I’m aware you can only copy and paste attributes. However, if you are able to drag all the pieces of one angle into one line in your timeline, you could easily select all those clips and past attributes to all of them at once.
    Another way that could be much more time consuming is to export each angle with the colour correction on it, naming it exactly the same as the original clip. Be sure not to save over the original clips. Then remove the original clips to a different folder and place those new colour-corrected clips in the place the originals sat. Then re-connect.
    The multiclips should then become colour corrected.
