Activity Forums Adobe Premiere Pro Multi channel Audio issue
  • Multi channel Audio issue
    Posted by Rojapathi Devarala on December 8, 2016 at 8:11 am
    Hi All
    I am using Premier pro CS6 and i am exporting multi channel Audio tracks with PAN as MXF file format and i am importing to check the audio its showing as one track empty.
    my export is
    track 1 is dialogue PAN is -100
    track 2 is dialogue PAN is -100
    track 3 is Music PAN is +100
    Track 4 is Music PAN is +100
    Track 5 is empty
    Track 6 is Empty
    Track 7 is Mixed
    Track is mixed
    if i imported this MXF file its not coming as it is .. its -100 & -100 is becoming one track and 2nd track showing empty …
    how will i get the PAN and tracks as it is??
    Please help .. TIA
    Tero Ahlfors replied 9 years, 9 months ago 2 Members · 3 Replies
  • Tero Ahlfors
    December 8, 2016 at 10:25 am
  • Rojapathi Devarala
    December 8, 2016 at 12:04 pm
    Hi Thank you
    After import is done with the mxf file .. i am dragging in to my timeline and its asking for the Option for Sequence setting and timeline setting.. i am selecting the sequence setting …
    My Issues is i want to import my audio file as it is with panes and tracks should be the same…
  • Tero Ahlfors
    December 8, 2016 at 12:26 pm
    Drag the file on the new item-icon below the project panel. You should get a sequence that matches the file.
