Activity › Forums › AJA Video Systems › Multi-channel audio capture with Kona 3
  • Multi-channel audio capture with Kona 3
    Posted by Christopher Tay on August 9, 2006 at 5:39 am
    Is it possible to do multi-channel capture in FCP 5.1, either via AES/EBU (8 channels) or embedded SDI audio (16 channels) in a single capture ?
    I would like to be able to capture 6 channels (via 3 x AES/EBU) but in the Kona 3 Control Panel audio input it still indicate that there is a need to map the source audio channels to input 1 & 2.
    -chrispy
    Christopher Tay replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
