Multi-camera shoot
The following is a copy of an email I just received, off forum (See my previous post, please.)
I need your help.
Your comments and suggestions on Cow always seem to be dead on. This is why I’ve turned to you with these questions.
First, I’m doing a 6 camera shoot in the US for a French company. They want PAL.
My first approach is to us HVX 2000’s and HVX – 500’s to do the shoot, all on P2 with monitors only for the director. (This is a budget thing and the French do not like to live mix.)
They at first requested DVcam/PAL.
I’m suggesting that the 2000’s and 500’s will do a superior job outputting a native PAL Format. Agree? What format would you use?
How can I sync the cameras? Would continuous run TC using a “Jam Box” or other sync Box be the answer?
Next, I’ll need to sync a Multi Track audio recorder to all, either the Alesis HD 24 or The Sound Device 788 T. Any ideas here as well?
I hope I haven’t overstepped my requested favor.
Please help when possible.
Thank you,
My reply:
you are the second person to contact me directly. That negates the value of the Cow Forum. Every post is a potential learning moment for everyone else. Also, others there may have better solutions that I do. I urge you to place this post on the Cow now. But I do thank you for your vote of confidence.
In the mean time, in response to your questions: some of these are above my real knowledge. For instance I never have done multi-camera shoots. I am keenly aware of the problems that poses for post, as well as some solutions.
Ideally, you want to jam all cameras to the identical time code, though also take care that output from each is properly identified (camera a, camera b, etc). In post the editor will want to line all the cameras up on timelines so that all cameras rolling at the same time are locked together.
I am not sure whether or not you can do that with the cameras you describe. If you cannot, a workaround is:
* have a clapper slate positioned so that every rolling camera can see it
* be sure the slate is correctly named; the clapper needs to sing out the name, take number etc. so that the editor can also sync up the sound in post
* make sure all cameras are focused on the slate before the clapper person claps it (can also be a smart slate)
* to reduce the need to repeat the above, once cameras start rolling they all go on rolling until the director calls “cut” which he should do as little as possible (it will take significant time to line up all the cameras for each clapper-start)If I understand your DVcam/PAL question, the French are proposing to shoot SD. Of course the HDV output in PAL will be superior, but do they have the means to handle that in post?
Rick Wise
director of photography
and custom lighting design
Oakland, CA
https://www.RickWiseDP.com
https://www.recessionvideo.net
https://www.linkedin.com/in/rwise
email: Rick@RickWiseDP.com
