Activity Forums Adobe Premiere Pro Multi-Camera Problem
  • Multi-Camera Problem
    Posted by Rob Weidner on January 28, 2009 at 11:09 am
    I am trying to do a multi-camera edit and i have all of my clips in a sequence and i have nest that whole sequence into another sequence but when i open the multi-camera window there is only one source available to change between, and it happens to be the one track that is selected back in my original sequence. If i change what track is selected then it changes in the multi-camera window but still only gives me 1 track. Multi-camera is enabled on everything. When i try to go in and record in the multi-camera window nothing happens because there is only 1 track not the 3 tracks that i have in my sequence. If anybody knows what i am doing wrong or knows what setting i need to change please help!!!
    Rob Weidner replied 17 years, 8 months ago 2 Members · 2 Replies
  • Mike Allmendinger
    January 28, 2009 at 8:26 pm
    Rob,
    1). Sync your tracks in a comp.
    2). Drag that track into a new comp.
    3). Enable multi-cam on the new comp.
    4). Open the multi-cam window. The bottom track in your 1st comp will be the shot initially selected in the multi-track window, but you can “switch” to another by clicking on the shot you want to start on.
    5). Hit the record button and switch between cameras.
    You should be off and running…
  • Rob Weidner
    January 28, 2009 at 9:27 pm
    The problem is that i can’t switch between shots. I know what you are saying and i have done all of that and when i double click on the comp that has the multi-camera enabled it brings me to my source window. In the source window i can click back and forth between shots but when i try open the multi-cam window it is just one shot. Whatever track is selected. i will show you a picture of my screen.
