Activity Forums Adobe Premiere Pro Multi camera mode slow in cs5
  • Multi camera mode slow in cs5
    Posted by Tim Thompson on September 17, 2010 at 4:56 pm
    Ok, I’ve upgraded my system, updated all my software, even the bios on my motherboard.
    I am perplexed at why multi-camera mode in cs5 is still not working. Here is my process:
    I start a new project
    Video settings are DVCPROHD 1080i 60 MXF files, they show up as P2 in the media browser
    – drag my video clips onto the timeline on different tracks. One at a time.
    – sync them up
    – nest them
    – Enable multi camera mode
    – Open multi camera monitor
    – Render the timeline, actually there’s some weirdness going on here too. When I press play, it
    hesitates a few seconnds. NOTE: At first, there is no red line to indicate that I need to
    render. I get strange results trying to play. So what I do is make an edit, like make a cut in
    one of the video tracks and the red line shows up for the entire work area. Then I render it and
    hit play.
    RESULTS:
    – It will go along fine for about 10-15 seconds, sometimes longer, sometimes shorter, then it
    starts to get jittery. Somestimes the video just stops, but I can still hear the audio.
    If I let it keep going, the video eventually catches up but I am unable to make
    good cuts. It will let me select cameras, but that slows it down too.
    So here’s my system:
    Windows 7 Pro
    i7 920 2.67ghz
    24 gigs of ddr3 1600
    4 hard drives in the following config
    – 1 tb non-raid for os and programs
    – 2 drives, 1 tb each on raid 0
    – 1 tb drive that contains my original video
    – Scratch, cache, and exports are on the raid drive
    – Project is on the original video drive (I’ve tried putting these in every other location possible)
    – OS and Programs keep to themselves
    Graphics card is a Geforce GTX-470
    800 watt power supply
    Oh yeah, I updated the bios on my ASUS P6T DELUXE V2 MOTHERBOARD
    Bill Skinner replied 15 years, 12 months ago 2 Members · 1 Reply
  • Bill Skinner
    September 18, 2010 at 8:58 am
    Tim,
    I am by no means an expert here but I was wondering if you are using the Mercury playback in software or hardware mode?
    Bill
