Activity Forums Apple Final Cut Pro Legacy Multi-camera editing and simple title questions
  • Multi-camera editing and simple title questions
    Posted by Todd Vanslyck on June 13, 2005 at 12:19 pm
    I’m beginning work on a college graduation using 2 cameras. During the handing out of the diplomas (which is the majority of the video), i’ll be cutting back and forth between two shots. Does fcp 4.5 have some sort of multi-screen effect that would make this type of editing easier?
    Also, I have to put 400+ names on screen (ugh!). I’m new to fcp, what is the easiest way to type out down and dirty titles? I have live type, but that seems like a huge, time intensive process. I formerly worked with Avid and the cheesy titler is starting to look good right about now…
    tVs
    Peter Wiggins replied 21 years, 2 months ago 3 Members · 4 Replies
  • Bouncing Account needs new email address
    June 13, 2005 at 1:11 pm
    You should always do a SEARCH POSTS before asking a question.
    There are scores of these same discussions to be found here.
    That said.
    The new FCP 5 has a true multi-cam capability but for years, with earlier FCP versions, many of us used the following:
    Syncing all of your video takes on separate layers is a preferred way to edit these kinds of things.
    You can just stop playback at each point you want (need) a cut and click thru each of your angles, picking the one that best-fits the mood.
    OR… You can “shrink” one or all of the video tracks (with “Scale” in the Motion Tab) and position each so that ALL tracks are visible (though small) at the same time. Depending on your system (and the number or tracks) you may need to render this temporary “split-screen” so that it will play in real-time.
    This will make fast work of your cut decisions.
    Each time you decide which of the shots you want in the final edit, slice it (razor blade) on both ends, and “shift-drag” (won’t slip) it up to a new, TOP video track (which will be ultimately be your “final” track.)
    After you are finished making cut decisions, select ALL the clips on this TOP track and “Remove Attributes” so all the video will snap back to full size and normal position.
    Then add any effects.
    As for Titles:
    Use “Title 3D” and NOT the FCP native Titlers.
    “Title 3D” (from Boris) comes on the original FCP install disc, so if you don’t see it as one of your title options, grab the install disc and CHOOSE to install it.
    Just create the first Title and –add it to the timeline– with the right font(s), colors, and sizes. Position it correctly (remember that the vertical position MUST be an EVEN WHOLE NUMBER in the Motion tab).
    Keep in mind how this composition will look with the LONGEST names.
    Next add the “Opacity” RAMP-UP and RAMP-DOWN timings (for the dissolves in and out.)
    Then, from, the timeline, double-click this completed Title back into the viewer and simply drag it from the Viewer over into your Bin.
    This first title will be your “template”.
    You can keep dropping this “first one” from the Bin right back onto the timeline when you want a new Title.
    Just remember after you drop it onto the timeline EACH TIME to:
    1. Double-click it back into the Viewer
    2. “Type OVER it” with each new name.
  • Todd Vanslyck
    June 13, 2005 at 1:24 pm
    thanks matte
    I had done a similar editing technique using multiple cams w/avid, I’m due for the fcp5 upgrade in the mail today, so i’ll check it out. thanks for your help, it will save me lots of time.
    tvs
  • Peter Wiggins
    Todd
    [Todd VanSlyck] “Also, I have to put 400+ names on screen (ugh!). I’m new to fcp, what is the easiest way to type out down and dirty titles? I have live type, but that seems like a huge, time intensive process. I formerly worked with Avid and the cheesy titler is starting to look good right about now…
    Down & dirty??? Make your first tilte on a new video layer, size & position to suit. A good idea here is to check who has the longest name so it all fits
    Then alt drag the title to your new position, leaving the old version
    Double click to get into viewer and tap in new name
    repeat
    Why not ask the college for a spreadsheet of all the names – then you could cut, paste & get the names exactly right.
    Peter
    https://www.peterwiggins.com
  • Peter Wiggins
    June 13, 2005 at 1:28 pm
    [Matte] “You should always do a SEARCH POSTS before asking a question.
    Kind of like saying one should always fill out their profile before posting? 🙂
    Peter
