Activity › Forums › Adobe Premiere Pro › Multi Camera editing
Posted by Richard Angle on October 6, 2012 at 6:28 pmCan multicamera editing in cs6 ONLY be done “on the fly”? Can jkl keys be used after hitting the record button to pause and/or shuttle to the next specific edit point to choose the desired camera angle? If I pause the video during a multicamera edit, it stops the multicamera function and I don’t understand why. Am I missing something or does multicam editing work only in a live playback situation?
Richard AngleAxel Arzola replied 13 years, 11 months ago 3 Members · 4 Replies -
Roel Bus
October 7, 2012 at 11:14 amRichard,
In my limited experience with this in Premiere (but have done lots of it in Final Cut), I do think it is a little clunkier than in FCP. The actual multicam cutting from one angle to another happens in the multicam window, but then updates in the timeline. If you want to fine tune and tweak, you can obviously still do that with roll and ripple edits in the timeline. If you leave the multicam window open, it gangs and updates where the time indicator is in the timeline.
A few glitches on my machine (and I don’t think they are supposed to happen…):
When I hit stop to pause the multicam edit, it creates a cut on the timeline and often, but not always, switches angles at that point…
The JKL keys functionality stops working after you switch to the second angle. I can use it to navigate in the beginning, but it stops after the first switch…
My workaround is to rough cut in the multicam window (and the record button seems to be just decoration, because it cuts in the timeline, even if I forget to press it), and then tweak in the timeline.
The clips always stay multiclips, so you can always turn on the multicam window and switch angles again. Alternatively, right-click on the clip itself, find “multicam” and switch the angle there.
A bit lenghty, but I hope it helped a little.
Cheers,
Roel -
Axel Arzola
October 7, 2012 at 10:06 pmMuticam emulates a live switcher, as Roel mentioned, you can do your rough cut on the multi cam and tune it on the timeline with the regular tools.
But if you want to change a clip to a different angle the fastest way is to select it in the timeline and hit the angle number you want it to change to. In the timeline you can use the jkl and pg up & pg down to move to previous and coming cuts.Axel Arzola
http://www.facebook.com/arzolafilm
Richard Angle
October 11, 2012 at 5:34 pmThank you both for responses. I just feel that the multi camera tool is half broken. I want to utilize the simultaneous multi-clip viewer with my normal jkl workflow. I want to simply navigate to my cut point, look at the multiple angled clips, and mouse click on the chosen clip.
Instead were having to do a live rough cut and then go back and redo every cutpoint with the ripple tool? Why not just do it right the first time around?
Adobe has unfortunately confirmed that it is not in the current plans to do any changes to the tool. They suggest stacking layers and resizing each clip in the program monitor. This was my old multi-cam workflow back in FCP3 about a decade ago.
I am on the trial version of CS6. I think I might owe Edius a look before making any Premiere plunges.
Axel Arzola
October 12, 2012 at 5:48 pmI’m sorry Richard, but I have to disagree on that. I have been cutting multi cam events in Premiere for over 5 years and there is nothing wrong with it. You just have to get used to it. I don’t understand what do you mean with staking up layers and resizing. Why would you need to do that?
Also, If you have the multi cam window open, you can select the clip and hit the number of the angle, as simple has that.
Please, give it another chance, I tried doing multi cam in FCP 7 and it was a nightmare.Axel Arzola
