Activity Forums Adobe Premiere Pro Multi camera editing
  • Multi camera editing
    Posted by Kit Webster on September 18, 2012 at 12:36 pm
    I have filmed an arts installation from 5 different angles, the installation is a looping video installation so each clip has to match up exactly to sync the video, however each clip has different start points so when I import them together to create a multi camera sequence they do not sync up..
    What I have done is to create a marker in the timeline and then sync them up in the timeline, however this seems like a non intuitive way of selecting the correct angle at the correct time.
    What is the best way to go about using multi angle clips that start at completely different times during the filming process?
    Thanks.
    Kit Webster replied 13 years, 11 months ago 2 Members · 2 Replies
  • Jan Bauters
    September 18, 2012 at 4:21 pm
    Put a inpoint in each clip at a sync point, select all the clips and make a multiclip based on in points
  • Kit Webster
    September 18, 2012 at 4:27 pm
    the problem I have is some of clips I have dont cross over but happen at completely different points during the installation.
