Activity Forums Avid Media Composer Multi camera DVCPRO HD 720
  • Multi camera DVCPRO HD 720
    Posted by Dennis Mcelroy on March 20, 2008 at 9:16 pm
    Can anyone tell me the minimum hardware requirements to be able to stream and view (4) cameras at once in a multigroup if the source material is DVCPro HD 720 coming of a P2 card.
    This will be coming directly off the P2 card. I have what I need to be able to view the 4 cams in the FCP world, not sure if it would be the same in AVID. Could a 2.5 Ghz processor with 4gb of ram and external esata storage hack that? Would much rather work on an AVID given the obvious multi-camera advantages within the software, but I’d rather put the AVID on a separate system/computer altogether and not have it battle my FCP setup which is being run on a 3.0 Ghz, 4gb ram 8 core mac pro.
    Dennis
    Jon Zanone replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jon Zanone
    March 21, 2008 at 11:29 am
    Traditionally multicam is done at an ‘m’ resoulution. If you work at ‘m’ resolution, any ‘approved’ system will work fine. You can use higher resolutions, but you won’t get real-time playback. You’ll only be able to scrub through the footage.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
