Activity Forums Adobe Premiere Pro Multi-camera audio
  • Multi-camera audio
    Posted by Warren Morningstar on April 28, 2010 at 2:42 pm
    Please help me understand how to do this. I have a multi-camera timeline where I mixed down the audio (more audio sources than cameras) so the master track has what I want. I nest that sequence in a new one. If I don’t enable multi-camera editing, I hear the master audio track from the original sequence. If I enable multi-camera, I hear audio track 1. So how do I do my camera cuts while listening to my final audio?
    Mike Trainor replied 16 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Jeff Pulera
    April 28, 2010 at 3:07 pm
    Hi Warren,
    I rarely use Multicam and am not in front of Premiere right now to test anything, but here’s my idea for what it’s worth – from the edited timeline with your master audio edits, export a .wav file of the whole thing, creating a “Master audio” clip. Bring that new .wav file into the MultiCam sequence on Audio 1. Hope it works for you
    Jeff Pulera
    Safe Harbor Computers
  • Warren Morningstar
    April 28, 2010 at 3:15 pm
    Thanks, Jeff. Great minds think alike . That idea occurred to me after I posted. Using it right now. Works fine, though it seems the long way around.
  • Eric Monroe
    April 28, 2010 at 10:29 pm
    I made a video to show you how to do this….as soon as it loads to vimeo I will post you the link.
  • Eric Monroe
    April 29, 2010 at 12:54 am
    Here is a video of how I do my multicam workflow.
    let me know if you have any questions, but this will definitely fix ya up to hear all your audio sources.
    link:
    https://vimeo.com/11312471
    April 29, 2010 at 11:48 am
    Eric,
    Thanks so much for taking the time to do the video. Your solution is much better for me than the work around Jeff offered and I stumbled upon myself.
    To me it would be logical that Premiere reads the master track of the nested sequence. Maybe they fixed that in CS5….
    Thanks again.
  • Eric Monroe
    April 29, 2010 at 4:30 pm
    no problem at all…..glad it helped ya.
    I learn on this forum all the time too….so whenever I do know the solution to something I try to help out. ;o)
    have a great day!
  • Mike Trainor
    July 30, 2010 at 7:18 am
    Eric, Did the video move? The link seems not to work. Can you re-post? I’ve never been able to figure the audio out for multi-cam. I think I am like the others in that I would like to mix together the audio inputs from the different cameras into the final multi cam output – and I can’t figure it out.
    Mike
