Activity Forums Adobe Premiere Pro Multi Camera Adjustment Layer
  • Multi Camera Adjustment Layer
    Posted by Gene Weglarz on November 10, 2013 at 1:59 pm
    I have a three camera sequence. I have an adjustment as the top video and added some color correction to the adjustment layer. When I set up the Multi Camera Sequence, the color correction is not showing up. When I tried to disable that one and add the adjustment layer to the nested multi-camera sequence, the multi camera window goes black.
    Anyone else have this problem?
    Gene Weglarz replied 12 years, 9 months ago 2 Members · 2 Replies
  • Casey Culver
    November 11, 2013 at 3:01 pm
    When you’re viewing your multicam window, you’re only seeing the single track that the multicam lives on, not the entire timeline. You select this track in the lower center part of that window. So if your multicam is on track one, select track one, track two > select track two etc. Because you are only seeing that single track, the adjustment layer modifications aren’t seen.
    If you nest your multicam with an adjustment layer, your multicam window is no longer seeing a multicam in the track you’ve selected – it’s seeing a nested track which it isn’t designed for, and therefore displays nothing/black.
    I understand why you might want to see your adjustments during the edit – so you get to cut within the mood/context of the final piece. However, the program isn’t designed to do that > most likely because playing back multiple tracks with applied color correction and effects simultaneously, and doing so all while allowing you to make real time edits, would probably take a spaceship size memory/processor 🙂
    Hope this helps.
  • Gene Weglarz
    November 11, 2013 at 8:24 pm
    I created a new multi cam sequence and then added the adjustment layer to it after I was done editing. Now the CC is showing up.
    Thanks for your help.
    Geoffrey
