Multi-Cam with multiple sync points
Hello everyone.Although I’ve found a few answers to my problems before,this is my first post.
I’ll try to explain my situation as best as I can.I shot a theatrical play with a friend and colleague of mine a few days ago.It was a 3 camera shoot with one camera fixed on a wide shot of the entire stage,the other doing medium shots focusing on the part of the stage the action was taking place,and the third for close-ups of the actors.
The play was in 2 parts, with the first one being about 80 minutes long and the second one just a bit over the 60 minute mark.We were shooting miniDV and were unable to locate 80 minute tapes,so we had to break up the first act in 2 tapes,and change tapes during the set changes between acts.But to avoid missing out on anything,we had decided beforehand to have one of the cameras change at a different time than the other two.
So 2 of the cameras changed at about 35 minutes into the play while the other changed at about 45 minutes in.
So in order to have the full first part of the play I have to sync 2 tapes from each camera,with varying sync points.
And I haven’t found a way to place more than one sync point when grouping clips.But this isn’t the only problem.
After the shooting was done,my colleague told me that since he was afraid that he was going to run out of tape before the end of the second part,he would stop recording during the set changes.
So now the entire second part from his camera(which was doing the close-ups by the way) is split in various clips,that need to be synced with the other cameras.So what I need to know,is there a way to place more than one sync points in multi-cam editing and have AVID fill the gaps with black?
Or can I sync them manually in the timeline,and then turn that timeline into a multi-cam?I should point out that I’ve already done 2 multi-cams before but never had to find more than one sync point because all the cameras were running the entire time.So i’m a bit familiar with the multi-cam editing interface.
Thank you very much…
