Activity Forums Apple Final Cut Pro Legacy Multi-Cam w/Different Video Formats
  • Multi-Cam w/Different Video Formats
    Posted by Ben Brodbeck on July 16, 2007 at 12:29 pm
    I’m doing a 4-Camera shoot that I intend to do a multi-cam edit on in FCP 6 w/a Quad Mac Pro.
    2 Cameras will shoot at HDV 720/24p
    2 Cameras will shoot at DV NTSC 30
    Audio will be captured from the HDV 720/24p source.
    My main concern is getting the DV & HDV footage to not have audio sync problems.
    I’d like all the footage/audio to sync up in the MultiClip.
    Any suggestions? Thanks in advance.
    Ben Brodbeck
    Devin Crane replied 19 years, 2 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    July 16, 2007 at 1:34 pm
    I’d think if you want the cameras to look anywhere near the same and show no syncing problems in a multiclip, you should shoot the same frame rate. I really don’t think that 24fps and 30fps material will look much the same at all, and certainly won’t look the same if you shoot SD and HD mixed up…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Bogie
    July 16, 2007 at 1:58 pm
    Audio should not be a problem. Regardless of the frame rate, one second of footage is still one second of time.
    It’s none of our business but we can easily infer from your question that you and your producers or clients have made all kinds of really weird
  • Ben Brodbeck
    July 16, 2007 at 2:12 pm
    Thanks for the input. The HDV cameras could shoot standard def like the other two DV cameras. I’ll go that route.
    Any further suggestions?
    Ben Brodbeck
  • Devin Crane
    July 16, 2007 at 6:51 pm
    You will definetly have to shoot in the same codec for Multicam to work. Even with the new Open timeline Multicam doesn’t support different formats. Even IMX 50 and 30 will not mix for me. Has to be the same DV, HDV and DV will not be able to cut together in Multicam.
