Activity Forums Adobe Premiere Pro Multi Cam Sync Hell!
  • Multi Cam Sync Hell!
    Posted by Austin Steele on August 3, 2018 at 6:35 pm
    Every time I sync 2 cameras in Premiere using the Multi Cam Sync function, I get issues. In this case, a Sony a7sII and Sony fs7. Some of the 2 camera shots sync fine. Others sync and combine 4 different shots together. So I get a multi cam clip with 4 different angles, 2 that don’t match. Sometimes I only get one camera to sync even tho I shot 2 camera.
    Basically, 1/2 the time something is screwed up and just weird. I realize it could be audio, but we clap synced almost all our shots so that really shouldnt be an issue.
    Any ideas ?
    Greg Janza replied 8 years, 1 month ago 2 Members · 3 Replies
  • Greg Janza
    August 3, 2018 at 9:05 pm
    Do you have problems if you make use of your clap sync and sync using in point?
    Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
    Adobe CC 2018 |Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
  • Austin Steele
    August 3, 2018 at 11:12 pm
    Do you mean by doing a manual sync? No that works fine. Just time consuming.
  • Greg Janza
    August 4, 2018 at 4:49 pm
    maybe provide some screen capture images to clarify your problems.
    I’ve never run into any syncing issues with multicam so your problems are a bit confusing.
