Activity Forums VEGAS Pro Multi-cam shooting and editing
  • Multi-cam shooting and editing
    Posted by Norman Willis on July 7, 2009 at 5:41 pm
    Hello.
    Is there an easy way to do multi-cam?
    If I have two of the same camera, and use a clapper board to make an audio synch point, I think I just line up the two footages on two tracks, parallel to each other.
    Then is there a quick and easy way to switch back and forth between the two timelines as I play through the timeline one time, and come up with a composite track?
    Thank you,
    Norman
    Jim Geiman replied 17 years, 2 months ago 4 Members · 5 Replies
