Multi-cam Sequence Footage Out of Sync Problem
I have been working on a multi-cam sequence at home for the past week. I have just opened the same project on a different computer at my work office and now 2 out of the 5 tracks are now visibly out of sync from each other. (About 5 frames difference)
Currently editing in Premiere Pro 2020.
All footage was recorded on XD Cam as MXF files.
All cameras are the same frame rate 29.97, 1440 x 1080Any help on this would be very appreciated. This is not the first time I have run into syncing problems with this set up.
