Activity › Forums › Adobe Premiere Pro › Multi-cam only visible on track 1?
  • Multi-cam only visible on track 1?
    Posted by Brad Bussé on August 15, 2014 at 12:49 am
    My first time using Premiere’s version of multi-cam. When I create a multi-cam group and insert it into a sequence, I can preview the multiple streams by switching the canvas to multi-cam. But when I drag a clip up to v2, I can no longer see the multi-cam preview section on the left half of the Canvas, only the composite on the right half. How can I see it on all tracks?
    Herb Sevush replied 12 years, 1 month ago 3 Members · 4 Replies
  • Vince Becquiot
    August 15, 2014 at 1:54 am
    Hi Brad,
    Make sure that track is selected on the left side.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Herb Sevush
    August 15, 2014 at 5:38 pm
    [Brad Bussé] “How can I see it on all tracks?”
    The multicam preview monitor (the left side matrix in the program monitor) only works on the lowest tabbed video track. If your material is on track 1 and it is tabbed, you will see the matrix. If your material is on track 1 but it isn’t tabbed, you will not see the matrix. If you want to see the matrix based on clips on track 2, then track 2 needs to be tabbed and the track 1 tab needs to be off. There is no way to have consecutive shots on different video tracks and have the matrix show them both. The good news, such as there is, is that you can cut and switch angles on a clip that isn’t in the matrix – the angles are still available even though the preview monitor isn’t showing them.
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
  • Brad Bussé
    August 15, 2014 at 5:39 pm
    Thanks, Vince. So it looks like in addition to enabling track 2, you also have to disable track 1 for the multicam clips to properly display for footage that is on track 2, and vice versa for footage on track 1.
  • Herb Sevush
    August 15, 2014 at 5:42 pm
    [Brad Bussé] “and vice versa for footage on track 1.”
    No, you don’t have to un-tab video track 2, because video track 1 is the lower track and has precedence. As long as Video 1 is tabbed you will always be able to see the matrix on it, no matter what the tabbed state is of the other tracks.
    Herb Sevush
    Zebra Productions
