Multi cam on a budget & capturing clips and automation of relative position in timeline?
This might be a wish list item, but does anyone know of a way to drop video clips shot on blacked tape into the same relative position in a timeline as they were with their relative timecode positions on the tape.
If that sounds a bit odd, let me explain the scenario, I video circuit racing, using amongst other things 3 or 4 mini dv cams left static shooting continuously until each tape runs out, lap times are about 40secs, so once a lap there’s at most 6-7secs of footage that’s of relevance. I edit the 10min races as ‘Live’, and depending on the level excitement, either render tham as ‘live’, or then edit out the boring bits. To begin with I was just capturing those short clips, however such was the fiddle on trying to sync each clip with a high manned camera (me) from my vantage point and one or two helmet cameras on vehicle. Its not so tricky but being a bit pedantic, I do find myself getting fussy of syncing to shots to the exact frame, but in an effort to speed up workflow, I’ve just chosen to capture each 10min race in full, cueing them up on a 6 or 7 separate tracks in the timeline, and then chopping my way up and down the timeline.
Even in Standard Def each shoot is swallowing 60-70Gb of hard drive at a stroke, of which I actually use maybe 10-15Gb, even with a penchance for split screening. It seems wasteful, even if the edit workflow is surprising fast, I may have a 1.5terrabyte of storage, but its swallowing it fast. I should say yes I should delete the captured footage when the edit and render is complete, however later in the season, I wish to re edit footage for promo/showreel/highlight purposes, and the captured clip are so long, etc.
And no, these are consumer cams, so no genloc (?), and no capacity to run cabling anyway, this is DIY, Lo Fi outside broadcast at its finest. If there’s cleverness to be done it has to be after the shoot etc.
I’m sure there’ll be an elegant solution, but can’t find in the usual knowledge bases. Can anyone help?
