Multi-cam issues in FCP 6
I’m about to editing my second song from a concert and I’m having some issues. My first song had 8 angles and I was able to do it fine. Actually, there was a light-green render bar across the whole clip in the timeline and when I rendered it and played the multi-clip it only showed me one angle in the viewer. So I un-did the render and it seemed to work fine with the light-green render bar over it Now I’m on another song and I have 11 angles to play with this time. I set up my multi-clip and placed it in the timeline and Open synced it up and it will barely play for a few seconds and freezes. I changed the 16-up back to 9-up to see if it would make a difference and it didn’t.
I have my RT set to Unlimited and Video is set to Dynamic and Playback Frame Rae is also set to Dynamic. Scrubbing High Quality is checked and Multiple Playback and Full Quality are also checked.
All of my clips are set at DV/DVCPro 720×480 29.97. I have all other programs closed and my Mac is a Dual 2 GHz PowerPC G5 with 6 GB DDR SDRAM on it.
Any advice would be greatly appreciated…
Chris
