Activity Forums Adobe Premiere Pro Multi-cam in final playback?
  • Multi-cam in final playback?
    Posted by Eric Larkins on February 15, 2010 at 6:42 pm
    I’m having no problem doing multi-cam editing, but I want to take multi-cam footage and sometimes have it in the final clip at the same time (a baseball pitcher’s footage on the LH side of the screen, and the catcher on the RH side, for example)
    I want to know if it’s possible to have multi-cams in the final playback? If so, what is this topic called so I can search lynda and learn how to do it please?
    There’s so much on mutli-can editing, I must’ve somehow overlooked what I’m trying to find – if it is possible, and I can’t see why it wouldn’t be.
    Thanks for the help.
    Mike Velte replied 16 years, 6 months ago 2 Members · 1 Reply
  • Mike Velte
    February 15, 2010 at 7:07 pm
    https://www.lynda.com/home/DisplayCourse.aspx?lpk2=702
    Chapters 13-15
    In your original multicam sequence where you sync’d 2 tracks, select the clip in track 2. Open the Effects controls pallet and click on the word Motion. Note the bounding box w/ handles around the video in the Program monitor. Resize the clip to about 25% and drag it to the left edge of the screen. Same song for the clip in Track 1…except drag this one to the right.
