Activity Forums Adobe After Effects Expressions multi cam combination
  • multi cam combination
    Posted by Tom Ma on January 24, 2012 at 4:53 pm
    this may be more a scripting request, than an expression..
    I’ve been asked to help on a video.
    They are trying to achieve a “3D GIF” effect. (not entirely sure what that means)
    Footage will be shot on three 7D cameras mounted on a Steadicam.
    I am being asked to “braid” these three different video files together.
    Ideally a script, expression, or some automated way to do this so that the final frame order would look something like this:
    Camera 1 Frame 1: Camera 2 Frame 2: Camera 3 Frame 3: Camera 2 Frame 4: Camera 1 Frame 5: Camera 2 Frame 6: etc..
    (You can see that the image wouldn’t loop (1,2,3,1,2,3) it would ping-pong (1,2,3,2,1,2,3)).
    any ideas or help would be greatly appreciated!
    Tim Drage replied 14 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    January 24, 2012 at 5:37 pm
    you could try dropping the clips into a comp, duplicating the footage from camera 2 and ordering them in this layer order:
    1. camera 1
    2. camera 2
    3. camera 3
    4. camera 2
    and then use an opacity expression on all o f them like this:
    if (timeToFrames(time)%4+1 == index) 100 else 0;
    this would effect show and hid the layers in the order that you needed (1,2,3,2,1…)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Tim Drage
    April 13, 2012 at 11:19 am
    if you google 3D gif you’ll find out what that means which might help you know what you’re even making 🙂
    I’d bring the photos in as image sequences (or put the photos in a precomp as 1 frame long layers, use Keyframe Assistant – Sequence Layers) then time remap that with loop_out(“pingpong”,0) as time remap expression.
