Activity Forums Apple Final Cut Pro Legacy Multi cam behavior
  • Multi cam behavior
    Posted by David Powell on April 29, 2011 at 1:52 am
    I didn’t seem to have this problem the last time I worked on a multi-cam project. When I’m working with a clip, and play from the timeline, the view will switch to one up view while the clip is playing and then back to 2-up when I pause. And then sometimes it play two up all the time as I would want it to after screwing around with it. I’m not sure exactly how to control this and what I’m doing to cause either.
    I have multi-clip playback checked and “open” playhead sync.
    David Powell replied 15 years, 4 months ago 2 Members · 2 Replies
  • Brian Pitt
    April 29, 2011 at 4:55 pm
    I have had this problem before too. This only happened when the footage was rendered. See if that is the problem. If so, just click on the flim stip icon to the left of the track to hide it. Then click it again and your render files should be gone. Hope that helps.
    Brian
  • David Powell
    April 30, 2011 at 2:00 am
    Actually what I have found is that you must start play on “cam 1” and it will consistently play all angles with the TL in sync. I’m not sure why this is, but it’s consistent.
