Activity Forums Adobe Premiere Pro Multi cam Audio
  • Multi cam Audio
    Posted by Chris Johnston on March 29, 2006 at 5:01 pm
    If I do a multicam project in PPro 2.0 everything works fine. The audio is only from camera 1 by default? How would I get the audio from all 4 cams at the same time, or can I change it so the audios to play from each cam that is selected? (when I pick cam1- cam1 audio is playing…pick cam 2- cam2 audio plays etc etc)
    Sorry for the quickie question but the books are at home 30 miles away and the help files didn’t
    Chris
    Aanarav Sareen replied 20 years, 1 month ago 2 Members · 1 Reply
  • Aanarav Sareen
    March 29, 2006 at 6:20 pm
    Chris,
    When you are in the multi-cam window, there is a flyout option on the top right. Click on the arrow and select “Audio Follows Video”. This setting will make sure that whenever your video is cut, the audio is accompanied as well (cam 1 cut = cam 1 audio; cam 2 cut = cam 2 audio etc.)
