Activity Forums Adobe Premiere Pro Multi-Cam audio troubles in CS3
  • Multi-Cam audio troubles in CS3
    Posted by Eric Lines on January 22, 2009 at 5:41 am
    I’m working on a project that I shot on three separate cameras without timecode generators. I’ve spent hours and hours linking up all the footage only to discover that the “audio follows video” function doesn’t seem to work in the Multi-Cam monitor. Once I nest the source sequence into the multi-cam sequence the only audio that comes through is the audio from my camera 1. No other audio even registers in the final multi-cam sequence. Even if I have the “audio follows video” option clicked, the camera 2 and 3 protions still only have the audio from camera one. I’ve tried targeting each, all, and none of the audio tracks in the source sequence and still all that comes across is audio 1. Please help in any way you can. If there’s something I’m doing wrong or if there’s a way around this I’d love to know as soon as possible. I’m working on a deadline.
    thanks,
    -eric
    Eric Lines replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
