Activity Forums Adobe Premiere Pro Multi-Cam Audio Problem on CS4
  • Multi-Cam Audio Problem on CS4
    Posted by Giacomo Aschacher on February 22, 2009 at 4:17 pm
    Hi all, I begun an editing with multi-cam in Premiere CS4. I’ve just one audio source and three video tracks. Everything was working fine, i was able to switch between video tracks, keeping always the same audio track. Suddenly when i switched the camera, the audio track switched as well. How can it be? shouldn’t switch only video tracks?
    Jon Barrie replied 17 years, 7 months ago 2 Members · 1 Reply
  • Jon Barrie
    February 23, 2009 at 11:12 pm
    in the multicam window you should have the option to select which audio you are using. AUdio track 1 should be the choice.
    If you want you can then take the audio track clip that’s right and put it on another layer and just pull that out to full length and make the other track with the multi-cam cuts mute.
    – Jon 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
