Activity Forums Adobe Premiere Pro Multi-Cam Alternative
  • Multi-Cam Alternative
    Posted by Gabriel Angst on February 15, 2010 at 8:01 pm
    Hello. I’m trying to edit a music video wich i recorded with 6 cameras.
    However, as Premiere Pro multicam feature allows editing only 4 cameras,
    i would like to know if there is an alternative way to do the cuts. I was
    trying to find something like… (example) at time 0m0s video1 is
    visible; at the time 0m5s, the video2 is visible, etc. The only way i
    imagined would be working with the opacity (transparency) of the videos,
    as the upper videos hide the below ones…. but it would give me a lot of
    work.
    Can you suggest me something better? Thanks in advance.
    Sorry for my poor english.
    Gabriel.
    Gabriel Angst replied 16 years, 7 months ago 3 Members · 4 Replies
  • Dan Herrmann
    February 15, 2010 at 8:48 pm
    Gab-
    Why can’t you edit a a few cameras down to 1 or two streams and then do a four cam edit.
    I have used six cameras before and two were sationary un-manned. These were wide shots used when my action shots were not where we needed them.
    once you run through your 4 cam edit you can go back and correct or when you are done you can render out and then input you other shots or enter special effects as needed.
    I edit using HD streams with the Cineform codec on Dell 690 with dual 5470 and 16gb of mem.
    multiple hard drives
  • Gabriel Angst
    February 17, 2010 at 3:36 pm
    Thanks for the tips!!
  • Alex Udell
    February 17, 2010 at 8:12 pm
    Gabriel…
    1) Create a 9 layer timeline
    2) edit your cameras in sync to master audio on video tracks 1 – 6
    3) use SCALE and position to create a 6 picture split of all the layers
    4) use the title tool to create number lay overs that correspond to the track numbers over the video
    5) place title on video track 7
    6) Export your timeline as a clip
    7) place the exported clip on track 8
    8) Now you can see all your cameras in sync
    9) Reset the position and scale on the clips on tracks 1 – 6 so they’d all be full screen
    10) use the blade tool to split any clip and edit the split portion on track 9
    using this method of setup you can use pretty much as many cameras as you want….
    Alex
  • Gabriel Angst
    February 18, 2010 at 7:59 pm
    Thank you so much!
