Activity Forums Apple Final Cut Pro Legacy MULTI BITRATE windows media file
  • MULTI BITRATE windows media file
    Posted by davidmccann David mccann on January 8, 2007 at 10:54 am
    I need to export my timeline as a MULTI BITRATE windows media file for an internet tv station. I guess that it rates your connection and plays the best quality that you can handle. It seems that with flip for mac there are some presets but nothing with multibitrate. here are the specifications i was given,
    “”We use 3 different bit rate streams (all at 320 x 240 size ) these are all encoded as 1 wma file.””
    Audio encoding mode: CBR (constant bit rate)
    Video encoding mode: CBR
    2 pass encoding
    Audience: 340 Kbps
    Audio codec: Windows Media Audio 9.1
    Audio format: 40 kbps, 32 kHz, stereo CBR
    Video codec: Windows Media Video 9
    Video bit rate: 291 Kbps
    Video size: 320 x 240
    Frame rate: 24 fps
    Key frame: 8 s
    Image quality: 80
    Buffer size: 5 s
    Audience: 282 Kbps
    Audio format: 32 kbps, 32 kHz, stereo CBR
    Video bit rate: 241 Kbps
    Frame rate: 24 fps
    Key frame: 8 s
    Image quality: 80
    Buffer size: 5 s
    Audience: 148 Kbps
    Audio format: 20 kbps, 16 kHz, stereo CBR
    Video bit rate: 121 Kbps
    Frame rate: 15 fps
    Key frame: 10 s
    Image quality: 70
    Buffer size: 5 s
    I am trying to avoid exporting to dv tape and then re-capturing in premier to get this encode. Any help would be appreciated. Thank you.
    davidmccann David mccann replied 19 years, 8 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    January 8, 2007 at 1:46 pm
    I’d think you need Sorenson’s Squeeze with the Filp4mac plugin, or Telestream’s Episode Pro.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • davidmccann David mccann
    January 9, 2007 at 2:22 am
    there is no way to use compressor with the flip for mac plugin???
