Activity Forums Adobe Premiere Pro Multi audio tracks in nested sequence
  • Multi audio tracks in nested sequence
    Posted by Ron Darby on February 11, 2015 at 4:40 am
    Is it possible to have multiple audio tracks in nested sequence .
    Could I have a sequence with 3 video tracks and 6 audio track, drop it into a new sequence and get 1 video track and 6 audio tracks?
    When I try that I only get 1 audio track and 1 video track
    Ron Darby replied 11 years, 6 months ago 2 Members · 2 Replies
  • Sam Lanes
    February 11, 2015 at 10:24 am
    Hi Ron,
    If you highlight the video segments of the sequence only, then right-click and select ‘Nest…’, then you will nest the video only, leaving the audio unaffected.
    You will need to make sure that the ‘linked selection’ icon under the timecode at the top-left of the sequence is deselected.
  • Ron Darby
    February 11, 2015 at 5:59 pm
    That helps, Thanks
