Activity Forums Apple Final Cut Pro Legacy Multi audio outputs!
  • Multi audio outputs!
    Posted by Aaron Neitz on June 4, 2008 at 1:34 am
    situ: 7 spots all have 2 channel stereo mixes, but 4 spots have 3 channel mono splits. I’ve been working in a 2 channel timeline.
    I can’t seem to get FCP to map “A3” to audio output 3. On my audio tool I can see 4 outputs, but FCP maps everything to channels 1/2. I’ve moved my A3 audio down to other layers to no avail. I can make a new sequence and have 4 channels of audio, but can’t seem to get FCP to map A3 to output 3 no matter what I do.
    There must be an easy way. I don’t do this often.
    Thanks for help!
    aa
    Aaron Neitz replied 18 years, 2 months ago 2 Members · 3 Replies
  • Aaron Neitz
    June 4, 2008 at 1:41 am
    Ok, I got it jimmy rigged. if I make a new sequence with 8 audio tracks, and copy/paste my timeline… then A1 goes out to 1, A2 goes out to 2, and A7 goes out to 3.
    I’m confused. but it works
  • Jeremy Garchow
    June 4, 2008 at 3:43 am
    What’s up, Aaron haven’t seen you around in a bit.
    Let me get this straight.
    In your timeline, your have opened the sequence settings and chose 4 outputs in the Audio output tab?
    You leave ch 1&2 stereo, and channels 3 & 4 as dual mono?
    Then you right click click just under the track lock of A3 and you can’t get the Audio Outputs > 3 menu?
    Jeremy
  • Aaron Neitz
    June 25, 2008 at 5:44 pm
    Weeks later I’m back!
    Thanks Jeremy, that was exactly it. Had no idea that drop menu existed!
