Activity › Forums › Avid Media Composer › Multcam on avid Symphony
  • Multcam on avid Symphony
    Posted by Jack Neiswanger on June 4, 2005 at 6:41 pm
    when I use multicam how do you get the all the different cams in the source montior to play at one time. Right now the cam’s do not play all together. Is it because the footage is digitize at 2-1. Any help would be great. Thanks, Jack
    Michael Phillips replied 21 years, 3 months ago 2 Members · 3 Replies
  • Michael Phillips
    June 4, 2005 at 7:43 pm
    On Meridien based systems (such as Symphony), realtime multicamera play only works with “m” resolutions.
    Michael
  • Jack Neiswanger
    June 7, 2005 at 2:54 pm
    Mike, What do you mean by M resolution ? Thanks, jn
  • Michael Phillips
    June 8, 2005 at 3:56 pm
    If you go to the digitize tool, you will see resolutions that have an “m” next to them. These are intended for real time playback when using multicam.
    Michael
