Activity Forums Maxon Cinema 4D Mult-shader question
  • Mult-shader question
    Posted by Craig Whitaker on January 24, 2011 at 1:28 pm
    Hey everyone,
    When I apply the multi-shader to a cloner object, it only works if there is a single object in the cloner. If I have a few objects under the cloner, the multishader doesn’t respond accurately. Any idea what I’m doing wrong? Thank you.
    Best,
    Craig
    Craig Whitaker
    MFA Candidate
    New York University
    http://www.craigwhitaker.net
    Adam Trachtenberg replied 15 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    January 24, 2011 at 3:30 pm
    What do you mean when you say it doesn’t respond accurately?
  • Craig Whitaker
    January 25, 2011 at 2:13 pm
    If I have five objects in the cloner and five colors in the shader, each color is not represented…it’s still random.
    Thanks Adam,
    Craig
    Craig Whitaker
    MFA Candidate
    New York University
  • Adam Trachtenberg
    January 25, 2011 at 3:25 pm
    By default the multishader will just apply the first layer to every clone. If you set it’s mode to “index ratio” it will distribute the layers across however many clones you have. The real power of the mograph shaders is in controlling them with effectors that have their parameter>color mode turned on.
