Mulitple Independent Masks with motion
I am fairly new to AE, and I am trying to achieve a certain look for a project I am working on. I have a video file that will be behind a mask that is slightly moving. The mask (or masks) will be 2 or more shapes to create a window frame effect with 4 separate moving entities. Nothing specific needs to be masked out, I am just using it create visual interest. I want each mask to move slightly independently of each other to give it a little bit of motion. The closest I can find to the effect I am looking for is the commercials for Grand Theft Auto Liberty City Stories.
My problem is, I import my video as the bottom layer on the timeline. I add a new solid layer on top and create a mask. I invert that mask so I can see what I want to see (instead of seeing everything I don’t want to see), that works great. I can transform on that and everything is great in my world. Then my problem begins.
If I create another solid layer and create a new mask shape, I can’t get them both to show up like I need to (the window effect), it will only show 1 side, the other side is still black.
If I put both masks on the same layer I can use the blending modes to get the effect I want, but then I cannot use the transform function to move each mask independently.
I am sure it is my lack of knowledge with the program to get what I want, but I have been trying all kinds of variations with no avail. Anybody know how to create 2 different independently moving masks that mask the same video?
Thank you
Justin Hartmann
