Activity › Forums › Blackmagic Design › Mulitbridge SD Capture problem
  • Mulitbridge SD Capture problem
    Posted by Lance Cooper on June 28, 2007 at 2:09 pm
    I’ve upgraded to FCP Studio 2 (Quad G5), and updated the drivers for my Multibridge. I can capture fine through the SDI, but the YRB SD captures from my Beta SP deck are giving me fits. Here is what is happening. In my log and capture I get the “No Video” message. If I go to my system prefs and change to SDI, the image from my HD deck shows up on my display monitor. If I switch back to YRB in my system prefs the Beta’s image shows up on my display monitor, but not in my capture window. No matter which video settings I use in FCP, I can’t get the SD image to show up in the capture window, but it will show up in my display monitor so I know the Multibridge is getting the signal fine. Any help? Am I missing a button that I should be pushing?
    Andres Posada replied 19 years, 2 months ago 2 Members · 4 Replies
  • Andres Posada
    July 9, 2007 at 11:53 am
    I have exactly the same problem. Have you been able to solve this issue? Did you receive any help from Blackmagic? Thank you.
  • Lance Cooper
    July 9, 2007 at 1:03 pm
    Not yet. I haven’t contacted Blackmagic directly yet. I was hoping to see if anyone else had the same problem and had found a fix. I’ll contact them and if I find a solution I’ll make sure to post it. Good luck and let me know if you find anything.
  • Andres Posada
    July 10, 2007 at 4:16 pm
    I am pretty shure it is a driver problem. I hope they are working on 6.3, and that it will be out soon. BTW, are you able to get any analog audio in? I can’t. The bottom line for me is that all video inputs plus the analog audio input do not work.
  • Andres Posada
    July 16, 2007 at 3:14 pm
    Have you had any luck?
