Activity Forums Apple Final Cut Pro Mulicam Goes dark??
  • Doug Metz
    June 1, 2022 at 9:04 pm
    Select the clip in the browser, then check the Info tab of the inspector – could it be you’ve got the Active Video Angle set to the audio track?
  • Mark Smith
    June 2, 2022 at 5:00 pm
    Yup – I accidentally selected the th wav track as the active video angle. I was sure how I tripped over that setting all I knew was one moment I had a 2 cam multicam with audio, and then I looked up and there was only audio.
