Activity › Forums › Apple Final Cut Pro Legacy › MTV Delivery guidelines anywhere?
  • MTV Delivery guidelines anywhere?
    Posted by John Steventon on December 8, 2005 at 5:36 pm
    Hi there,
    Does anybody know where I can find definitive delivery guidelines for MTV Europe?
    I can work to my normal guidelines for other networks, but I’d really like to see how they’d prefer the audio levels for music to be delivered.
    If anyone can help let me know where to go, or knows the info themselves, I’d really appreciate a repsonse.
    Thanks in advance.
    John Steventon
    Fairline Productions
    http://www.fairlineproductions.com/johnedit.html
    John
    Success is merely a failiure to imagine more…
    G5 2.7Ghz, 4.5Gb ram, Blackmagic Decklink/multibridge, 5.6Tb Infortrend storage, FCP Studio 5.02, Makie MCU control, Yahama 5.1 surround, JVC DTV multi-format monitor, 2x23inch Apple monitors – and a partirdge on a pear tree.
    Chad replied 20 years, 9 months ago 6 Members · 6 Replies
  • Mark Raudonis
    December 8, 2005 at 8:56 pm
    Uh… how about calling up MTV?
    If you’re doing a show for them, the first thing they do is distribute their delivery requirements. It’s part of the contract.
    Mark
  • David Bogie
    December 8, 2005 at 8:57 pm
    You could start by telling us what you’ve already tried. The first stop would be … MTV. Their specs are either readily available or their technical contacts are far enough down the line that you can’t get them till they want you to have them.
    bogiesan
  • Andrew
    December 9, 2005 at 5:08 am
    ask the show producer there is a packet they give you, tells you how to do the end credits, the fonts, the audio mix and bunch of other stuff, what is does not tell you is that if you have lower thirds or some sort of graphic you need to leave the graphic but remove the title/names so that they can write what they need in there language. over all it’s pretty simple, I do/did all sorts of shows for them for US and international, you should only need 1 international tape and they (the rest of the world) uses that tape to create their show.
  • John Steventon
    December 9, 2005 at 9:18 am
    Firstly, thanks for all your replies. It’s not actually a programme that’s being delivered, just a music video which is getting sent to them – hence the lack of a) Someone to contact, and b) Any pre-contract stuff.
    Well, hell, it might be out there somewhere, but I’m just the dumb facility guy, no-one tells me a thing 🙂
    So my quesiton is really what level they’d expect the audio at. For adverts, I make the audio ‘tickly’ 6ppm. For normal TV programmes, I have general audio at 4 with transiants etc using the headroom up to 6ppm. But how do they expect the music? Mostly at 4 with some headroom? Or tickling 6?
    Ripping the audio in directly from CD plays about 8ppm, so that’s not an option, so I just wanted to know if there’s a preferred amount I should take it down to – so it’s generally at what on the PPM scale.
    Normally I have it to the music peaks at 6, which means it plays normally around 5ppm – but i was just looking for some particular guidance as the producer is also the producer for the artist, and is especially concerned about the audio levels matching everything else that plays on the channel.
    So if I had either a tech guidelines from MTV or something I can show him that proves I don’t just play it out at 8ppm, it would take some heat off me.
    Thanks again, in advance.
    John
    John
  • Walter Biscardi
    December 9, 2005 at 12:26 pm
    [John Steventon] “Firstly, thanks for all your replies. It’s not actually a programme that’s being delivered, just a music video which is getting sent to them – hence the lack of a) Someone to contact, and b) Any pre-contract stuff.”
    Simply call MTV and request the technical specifications for all Music Video Submissions. They will have a package or a PDF to download which will list everything that’s required including the tape formats and audio settings.
    I have a 60 page book from the Food Network that lists everything and anything I need to know about finishing a show for them and every network has one.
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Chad
    December 9, 2005 at 10:41 pm
    I do a lot of music videos, and some have ended up on MTV. The contract the label gave the producer or director will have the tech guidelines. You deliver to the label and they do the dupes and etc for the MTVs of the world. I know the audio is usually a -12db with peaks hitting zero.
