Activity Forums Apple Final Cut Pro Legacy MTS import woes…
  • MTS import woes…
    Posted by Paul Lumsden on August 11, 2009 at 4:50 pm
    heya,
    i’ve done a search for this, but only found an old thread that didn’t shed any light on my dilemma…
    i can’t import .mts files into fcp. i used a canon legria hf200 as a back up for a shoot. i copied across all the files from the camera’s sd card onto a local drive. upon importing into l&t, a window pops up saying –
    “AVCHD” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.
    the files are all there, and i can play back the media on the camera. i’ve tried converting the mtf files in mpeg streamclip and visual hub with no luck. i’m running fcp 6.0.6 so i’m assuming everything’s up to date…
    the only way i can see round it is to go through my analogue to fire wire box and crash import which seems a shame..
    is there another software codec out there i need to get? or is this format really only for windows based computers?
    Roloff De jeu replied 17 years, 1 month ago 3 Members · 6 Replies
  • Jeremy Garchow
    August 11, 2009 at 5:43 pm
  • Paul Lumsden
    August 11, 2009 at 6:16 pm
    cheers for that, i’ve given it a go and it looks like it doesn’t recognise .MTS files. i’ve emailed them though.
  • Jeremy Garchow
    August 11, 2009 at 6:24 pm
    Yeah, sorry about that.
    I do know that the file structure of all tapeless media must remain in tact, meaning you create a folder, then drag the contents of the SD card that new folder. Make a new folder for each card.
    What was the original file structure?
    Jeremy
  • Paul Lumsden
    August 11, 2009 at 7:37 pm
    no worries fella, it was worth a go. i got a very quick reply from mike at divergentmedia about this –
    Paul,
    The current version of ClipWrap does not support mts files. We have
    announced that our next version will, but it is not available for
    purchase yet.
    mike
    as the the file structure, i tried to import the data at several ‘levels’ (if that’s the correct term?) going from the AVCD folder with all the relevant data included to the individual .MTS files. this is a method i’ve used coming from P2 cards and i’ve not had a problem.
    i’ve just tried importing via my magila directors cut box, but the footage looks (unsurprisingly) awful. i may see if a mate with a pc can import – export the .MTS files in a format FCP can read.
  • Jeremy Garchow
    August 11, 2009 at 7:55 pm
    So you have a folder that you made, then a folder named AVCD, then all the relevant data there?
    Jeremy
  • Roloff De jeu
    August 17, 2009 at 9:12 am
    I’ve read in another thread here that Canon’s AVCHD files can be imported into FCP7 these days..
