Activity › Forums › Adobe Premiere Pro › .MTS files import into premiere with no audio
Posted by Peter Brown on December 8, 2011 at 10:38 pmI am shooting with a sonynx70 and when I import the .MTS file into premiere (presets AVCHD 1080p tracks 3-sterio 3-5.1
I get video but no audio. This is stumping the folks at adobe as well. any ideas here? Im stuck without being able to use that native mts formatTad Newberry replied 12 years, 11 months ago 5 Members · 7 Replies -
Ann Bens
December 9, 2011 at 3:11 pmWhich Premiere?
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Ann Bens
December 9, 2011 at 10:05 pmDelete footage from Premiere
Trash all your media cash.
Delete all pkf files if you can find any.
Restart Premiere with holding ctrl+shift+alt.
Import again in new project.
Hope that helps———————————————–
Petros Kolyvas
December 10, 2011 at 3:12 amIs the lack of audio in the source monitor or on the timeline?
We have seen lots of instances where audio doesn’t play back in the source monitor (in our case mainly from HDV sources.) As soon as they’re popped on the timeline, the audio appears and plays back without issue.
When you do put those clips on the timeline can you at least see the audio waveforms or is there no audio attached?
There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger -
Peter Brown
December 10, 2011 at 4:06 pmBruce
thanks for taking the time with regard to my problem. No audio in either the sourse monitor, or the timeline. My quick solution was to take the files into Brorsoft and convert to mp4’s, then use those in adobe. I know audio is in the mts because I can play in the brorsoft preview window, and the converted mp4’s have sound. So I went out and shot some video with the original camera at the original settings (1080p)and adobe(at the same sequence settings) brought it in with audio. not sure what happened. I hope it was an isolated incident. -
Keith Moreau
December 10, 2011 at 9:27 pmI have a Sony FS100. In 1080 60P LPCM audio mode, it doesn’t think there is an audio track, it does work with AC3 audio in that mode as well as LPCM in all other modes. Not sure if this is related to your problem but is is a NX cam issue.
Tad Newberry
October 8, 2013 at 2:17 ami’m a newbie here and was having the same problem. i shoot with a Sony NX-5 in the AVCHD codec, yielding me mts files. nice to see they can be edited here natively as was not the case in FCP. anyway, i would drag an mts into a newly-created AVCHD sequence. video, no audio. every time.
so i made a new sequence. chose a random codec (DVCHD in this case), dragged an mts into it – it asked me if i wanted to change the sequence setting, which i did) and voila! the clip had audio, as did all mts clips following.
hopefully that helped out someone else…
thanks for helping out a bonehead!
__________________________FCS3
2.66 GHz Quad-Core Mac Pro
6GB RAM
NVIDIA GeForce GT 120
…and a few TeraBytes o’ storage
(then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
