Activity Forums Apple Final Cut Pro Legacy MTS files & FCP 7. why, Why, WHY?
  • MTS files & FCP 7. why, Why, WHY?
    Posted by Gina monkaey Debartolo on August 3, 2012 at 1:06 am
    WHY won’t these stinking MTS files play nice with my FCP?
    Here’s my situation:
    * I am running FCP 7 on an iMac OS X version 10.7.3 (Lion).
    * I am attempting to import and convert MTS files from a Panasonic AF100 camera.
    * I have downloaded and installed the AVCCAMImporter (before I realized it works for Mac OS X 10.5, 10.6, but perhaps not for 10.7 Lion)
    * The raw files are already on my external drive, all ready to be logged and transferred. But when I go to do this, the MTS files are greyed out.
    I am seeing a lot of people bemoaning these transfer issues with the new FCP X, but I can’t find any info on converter programs that work with FCP 7/Lion. Ideas? Help? You all rock.
    Yoda Yun replied 11 years, 10 months ago 7 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    August 3, 2012 at 1:16 am
    You aren’t doing it right. You use LOG AND TRANSFER for tapeless media.
    here’s a tutorial:
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    Shane
    Little Frog Post
  • Gina monkaey Debartolo
    August 3, 2012 at 1:21 am
    I was indeed using Log and Transfer for this; I should have mentioned that. Thanks for the link to your video anyway; I’ll watch it.
  • Shane Ross
    August 3, 2012 at 1:46 am
    Are you fully updated to 7.0.3? Is the full card structure intact? And I mean FULL card structure…
    Shane
    Little Frog Post
    August 3, 2012 at 2:37 am
    Probably, but not 100% positive.
    I had fairly experienced camera operator/editor logging and transferring the files onto a hard drive for me (but using a MacBook Pro with FCP 6); now I’m trying to do the same on a few raw files that he didn’t get to.
    I’m following his same workflow but on a different machine and version of Final Cut, and I am unable to replicate his success.
    August 3, 2012 at 2:39 am
    Oh, and I am not fully updated to 7.0.3. I’m just at 7.0, if that makes a difference. Thanks for your help.
  • Werner Kruse
    August 3, 2012 at 8:09 am
    I recently ran into problems with .mts files. I had no idea where they came from, what camera, etc. It was only a folder with a bunch of .mts files. (It was not in its original folder either as it records from camera)
    I downloaded the plugins that I could find for FCP and tried Log & Transfer but no luck.
    I tried MPEG Streamclip, Compressor and a few other programs to transcode to Prores but no program recognized the files.
    Luckily I have Premiere Pro CS6 (Believe CS5 and up will work) and it recognizes almost any file format so I imported into PP and then exported as a ProRes file. That file was hen imported into FCP.
    There could be better ways but I had no time and was the easiest, quickest option for me.
    Good luck
    August 4, 2012 at 5:42 pm
    Thanks so much, Werner! I’ll try that!
    Gina
  • Rafael Amador
    August 4, 2012 at 7:09 pm
    There is another couple of options.
    One is ClipWrap (free trial), which can re-wrap the MTS files as QT (so you can import to FC), or convert to Prores.
    The other option is 5DtoRGB (free). This will also convert the MTS to Prores while processing the chroma properly (you will be going from 8bYUV-420 to 10bYUV-422/444). This is option will make the best conversion, but will be slower.
    rafael
    http://www.nagavideo.com
  • Michael Reiersgaard
    August 5, 2012 at 2:55 am
    If you have access to Adobe Media Converter that’s how I get around MTS files. My other editor doesn’t seem to understand I can’t use mts files by themselves and I always end up converting them to ProRes in Adobe Media Converter before I can start editing.
  • Christina Rule
    August 6, 2012 at 11:20 pm
    I ran into this issue before… My client sent me just the .mts files with no folder structure so I was unable to do the log and transfer in final cut.
    I find that HandBrake https://handbrake.fr/
    is the best for conversion. 1. It’s free and 2. It works fast and holds good quality. Hope this helps!
    http://www.christinarule.com
