Activity › Forums › Apple Final Cut Pro Legacy › MTS Files
MTS Files
Posted by Sascha Engel on June 29, 2011 at 4:44 pmHi,
I tried to find former posts on this one, but could not get a clear answer.
If I have MTS files and I wanna make them FCP 6 ready, can I convert them in Toast in a good quality?
I know, it works, but does Toast do a good job?Sascha
Isaac Brillant replied 15 years ago 4 Members · 9 Replies -
Sascha Engel
June 29, 2011 at 6:58 pmHi Chris,
I don’t know which compressor you are talking about, but if it’s the one from FCS, it does not accept MTS files.
Any other idea?Sascha
Chris Borjis
June 29, 2011 at 9:08 pmoh dear…oops I remember that now.
clipwrap will do it. I find it an essential tool at a very low cost.
Sascha Engel
June 30, 2011 at 3:03 pmHi Chris,
tried it. Actually Toast is better, even does a preety good de-interlaceing!
Sascha
Sascha Engel
June 30, 2011 at 4:24 pmTried that one right now…very good result.
Still: Toast is equally good. I am surprised myself, but it does hell of a Job!Sascha
Chris Borjis
June 30, 2011 at 4:53 pmMTS>ProRes with Toast?? and it looks good?
I never would have thought that possible.
interesting.
Sascha Engel
June 30, 2011 at 4:58 pmMe neither…and even more: I also converted the frame rate 29.97 to 25.
I did all the same with Clipwarp & Media Encoder – and Toast pretty much stood up to it.
Things you definitely would not expect!Respect to Toast!
Sascha
Isaac Brillant
September 4, 2011 at 7:24 pmDo you know if – using Toast or one of the other converter programs – you can import the MTS files you want to use and create a new folder structure that FCP could recognize?
I’d like to be able to just save my MTS files rather than backing up each SD card, and then if I want to bring them into FCP, create a new folder structure that L&T could read.
This way I could view them in FCP, in the L&T window, before having to transcode them all.
Also, which Toast are you using? I only have Toast 9…
