Activity › Forums › Apple Final Cut Pro Legacy › mts files
mts files
Posted by Bob Root on July 25, 2009 at 6:22 pmHi all,
I just received some (DVD) discs from a client with .mts files (along with AVCHD, CPI and a few others).
I am completely unfamiliar with this file format and how to open the files in FCP. Some other forum answers suggested using “log and transfer”, but it didn’t work for me.
I’m running version 6.0.5 on Mac Pro Quad core.
Any help or references would be greatly appreciated. I’m a bit stuck on this one.
Bob
Alan Langdon replied 15 years, 1 month ago 6 Members · 7 Replies -
Josh Olenslager
July 25, 2009 at 8:13 pmHi Bob,
ts files are streaming files for disc playback. You should be able to open them with a program like VLC or MPEG Streamclip. You’ll probably need to then transcode them into a format that Final Cut can recognize and work with. Both the programs above are freeware and have transcode capability. Hopefully this will work out for you.
Good luck!
Josh
Digital Media, Thought Equity Motion
Martti Ekstrand
July 26, 2009 at 11:05 amHe is asking about .mts files, not .ts ones. The .mts files comes from cameras using AVCHD compression and for FCP’s Log & Transfer to work they need to be still in the camera’s “PRIVATE” folder and it has to be unaltered by a computer or L&T refuses to recognize them. Just delete one file in “PRIVATE” and the entire content of it is ignored by Log & Transfer. One good workaround is converting with Toast 10 which reads naked .mts files and can convert to any Quicktime codec you have installed. This is actually my preferred method of converting. Toast also includes a video player that plays .mts files very well without conversion.
VLC can convert but only to a limited set of codecs and not with good quality. MPEG Streamclip does not read .mts file, hopefully that will be added. There’s is a shareware app called Voltaic that also handles .mts files as they are but it’s slower and transcodes somewhat softer than Toast and very much slower. It has handled some clips that Toast has not coped with though. Cineform’s NeoScene also handles .mts files, outputs to it’s own pretty good codec but costs more.
check out my shorts: https://vimeo.com/marttiekstrand
Russell Lasson
July 26, 2009 at 6:57 pmMartti, do you know if there is a way to just wrap an AVCHD file in a QT wrapper? Does Toast do something like that?
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net -
Bob Root
July 27, 2009 at 1:24 pmThanks for the responses.
L and T worked fine when dragging in the entire Private folder.
My mistake was trying to drag in the individual mts files. Lesson learned.
Thanks again.
Bob
Chery Day
January 4, 2011 at 7:36 pmThanks for this information. I have been given a drive with .mts files. I do have Roxio 10. How should I proceed in getting the files into Roxio? Any advice would be appreciated.
Alan Langdon
July 23, 2011 at 11:33 pmI am currently converting using the CONVERT option in Toast 11. The 720p resolution output seems to be encoding to Apple INtermediate COdec, not the most professional but OK for now… I’ll post back if something goes wrong.
