Activity Forums Apple Final Cut Pro Legacy .MTS file woes
  • Posted by Jason Siemer on July 7, 2009 at 2:05 am
    Hey there,
    Found some other links on this topic, but not sure if anyone ever mentioned the solution.
    Received a few DVD’s from a client which contain .MTS files. Trying to import them into
    FCP Studio 6.0.6. Can’t get FCP to recognize these files. Keep getting this message when I do log and transfer:
    “contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.”
    Help! (please)
    -Jason
    John Fishback
    replied 17 years, 1 month ago
    3 Members · 3 Replies
  • Craig Russillroy
    July 7, 2009 at 7:09 am
    Howdy
    Try putting the files into toast and transcoding the files from there – mts require a certain folder structure
    hope this helps
  • Jason Siemer
    July 7, 2009 at 11:12 am
    Much appreciated Craig,
    I actually was able to find a program called “Aimersoft Total Media Converter” which worked pretty
    well. Transferred them to Quicktime files with the highest resolution being 1280×720
    with the H.264 encoder. I made the bit rate 1200 kbps. Footage looks good but I’m not sure how it compares to the original .MTS files. There are also options to convert to .ASF, various .MPEG Versions, .MKV and XVID AVI. I’m doing the right thing by just making them .MOV files for the best quality to edit/export from FCP, correct?
    Sorry, this whole conversion things drives me batty!
    -Jason
  • John Fishback
    July 7, 2009 at 5:05 pm
    H.264 is not an edit codec so getting your files into a .mov format that FCP likes is a good idea.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
