Activity Forums Apple Final Cut Pro Legacy .MTS file to HD QT for FCP conversion software
  • .MTS file to HD QT for FCP conversion software
    Posted by Wayne Beckwith on February 22, 2011 at 10:14 am
    I have a Sony Handycam recording in AVCHD 1080i 50 MTS file format. There are quite a few MTS to X video format software about, but I was wondering if anyone can recommend one they have used?
    I have tied out a couple but disappointed with the results
    I basically want to maintain the highest quality format preferably QT for FCP
    Regards, Wayne
    Affi Zeng replied 15 years, 5 months ago 6 Members · 6 Replies
  • Shane Ross
    February 22, 2011 at 11:14 am
    LOg and Transfer in FCP not working? Clipwrap2?
    Shane
  • Chris Tompkins
    February 22, 2011 at 11:22 am
    You can L&T AVCHD files right into FCP.
    Chris Tompkins
    Video Atlanta LLC
  • Bernard Newnham
    February 22, 2011 at 12:06 pm
    Every time I try Log and Transfer with AVCHD Final Cut crashes – just disappears. I use Clipwrap, which does the job of reformatting very well.
    B
    bernie
  • Jeremy Garchow
    February 22, 2011 at 2:39 pm
    +3 for clipwrap.
  • Wayne Beckwith
    February 22, 2011 at 8:58 pm
    Thanks everyone. L&T worked once I figured out what I was doing wrong. Sounds like Clipwrap would be a handy addition to the conversion software arsenal.
    Regards, Wayne
  • Affi Zeng
    April 10, 2011 at 3:20 am
    In Final Cut you would open your log and transfer window and import the footage as Pro Res 422 which, while it creates larger files, is a great codec to edit with and I do so with most everything.I suggest you purchsed MTS Convert for Mac, because compressor is very slow and Final Cut handle AVCHD files when it finds them in their original file structure (either by connecting the camcorder or using a memory card reader), not isolated .mts files.
    https://fastblurayripper.com/how-to-log-and-transfer-mts-fils-to-final-cut-pro
