Activity Forums Adobe After Effects MTS file conversion
  • MTS file conversion
    Posted by Nick Leigh on December 16, 2010 at 4:32 pm
    I have a sony HDV camera that records in ACVHD and it stores it in the mts file format. I have read on here that AE doesn’t play so nice with mts files so I am wondering what format I should be converting the files to so I can work with them in AE. I will be using Adobe Media Encoder to do this.
    When I added these files to Media Encoder the default output was a f4v file and I used the PNG codec which I read somewhere on here from Dave L. Is this correct? Do you have any suggestions as to the best settings to use to do the conversion?
    Another question I have is about the file format. My camera records the footage in 1440 x 1080 (1.33). My desired output will be 1920 x 1080(1). I tried using the 1920 settings on a file for the conversion just to test it out. The resulting file looked fine to me but I am wondering if I am going to run into problems it AE if I do this? Should I convert them using the same settings as my footage? The reason I ask is because I have a image overlay on top of my footage for the entire video and when I use the 1.33 PAR the image looks distorted a bit where when I use the 1.0 PAR it looks great.
    Thanks for your help.
    Nick
    CS5 Production Suite
    Charlotte Kaufman replied 13 years, 2 months ago 3 Members · 6 Replies
  • Michael Szalapski
    December 16, 2010 at 4:42 pm
    I second everything Dave said. AE 10 (AKA CS5) works just fine with AVCHD files. You shouldn’t have a problem. You may find that it works a bit faster with Quicktime PNG files, you might not. Anyway it’s unlikely that you’ll have screwy problems like you could get in version 9 (and Heaven help you if you tried it in version 8 or earlier).
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Nick Leigh
    December 16, 2010 at 4:50 pm
    Well it is a hockey game that is about 50 mins long. I am going to need to compress it so it will be able to play on hte internet through our website but I will also be putting it on to DVD’s for those players that are still living the dream and want to make their wives or moms watch them play.
    Nick
  • Michael Szalapski
    December 16, 2010 at 4:55 pm
    If that’s your intended output, you definitely don’t need 1920×1080. DVD’s maximum resolution is 720×480 and the most I’d recommend for web videos would be up to 1280×720, but that’s only if you’ve got a nice amount of bandwidth to spare. (Now, you could just use YouTube or Vimeo and embed that on your site and you could do 1080, but most people don’t have a 1080 screen to view it on anyway.)
    – The Great Szalam
  • Nick Leigh
    December 16, 2010 at 5:21 pm
    Ok thanks for the info on the output size.
    Can I import my mts file that is 1440 x 1080(1.33) into a project that is 1920 x 1080(1) or is that going to mess with my pixels in my video. Again this is so my overlay image looks crisp rather than strecthed as it does in the 1440(1.33) project. The image is 1920 pixels wide and has a PAR of 1. Thanks for your time.
    Nick
  • Michael Szalapski
    December 16, 2010 at 5:45 pm
    I would recommend making your composition the size of your intended final output.
    However, if you want to work in the full resolution of your source footage, I would suggest doing it in a 1440×1080 comp. Just make sure that your other assets are being interpreted correctly (square pixels, etc.) and that you know how to use the aspect ratio correction switch on your comp window. Nothing should look stretched.
    – The Great Szalam
  • Charlotte Kaufman
    June 25, 2013 at 12:38 am
    I have a related question, regarding MTS files.
    1. Is it a problem that there is a redundancy in the naming of the .mts files, and that i will have several clips in the project with the same name? All the clips are organized into a folder structure based on date and roll, so i’m not worried about the name redundancy when i’m actually editing. I am worried that if the media gets disconnected Adobe won’t know which clip to look for, and may try to reconnect the wrong clip with the same name. Does Adobe reconnect based only of file name, or does it also look at the path?
