Activity › Forums › Adobe Premiere Pro › MTS audio clips not appearing.
  • MTS audio clips not appearing.
    Posted by Brad Wagster on September 12, 2016 at 12:37 pm
    I’m trying to edit MTS files on a Macbook Pro. When I preview any of the video clips in the Finder, there’s audio playing loud and clear. I’ve played the clips through VLC, Quicktime and through the spacebar media preview. Every viewing option has audio.
    But when I import them into Premiere, it’s as if the audio doesn’t even exist. Just for the hell of it, I imported the same files into Final Cut Pro X and the audio shows up just fine. Really frustrating.
    Anyone know what’s going on?
    Jeff Pulera replied 10 years ago 3 Members · 2 Replies
  • Paul Neumann
    September 12, 2016 at 3:10 pm
    Seems like a conform problem. Can’t say for sure without knowing your settings. Open the clip in another Adobe program (AE, Audition, Prelude) and then check it.
    Couple of versions back MTS audio would not hover scrub in Prelude before being ingested. This is when the conforms would be built and the ingest could be discarded and the clips would work just fine.
  • Jeff Pulera
    September 12, 2016 at 7:34 pm
    Hi Brad,
    For best results, copy entire contents of camera memory card to a new folder on hard drive. You want ALL the folders from the SD card, not just video clips. Premiere needs metadata to sort things out. Then in Premiere, don’t use File > Import, rather use Media Browser tab for the import. This method can make a big difference in many ways – playability, audio, seamless joining of spanned clips, etc.
    Don’t try this on existing Project, as Premiere can get confused when importing same clips twice. Try workflow using a New Project
    Jeff Pulera
    Safe Harbor Computers
