Activity Forums Adobe After Effects MPG2-DVD export option missed
  • MPG2-DVD export option missed
    Posted by Gianni75 on July 4, 2007 at 8:32 am
    Hi to all,
    I’ve a problem with AE7 PRO: when I want export a composition in MPG2-DVD format I don’t find this option in the list box. There are all format except MPG2-DVD.
    Could you help me?
    Thanks for your support.
    Ciao
    Gianni
    Gianni75 replied 19 years, 2 months ago 3 Members · 3 Replies
  • Skandaless
    July 4, 2007 at 7:19 pm
    Did you add your composition to the render queue? Or did you try and export from File – Export because you won’t find it there.
    So, add your comp to the render queue, click custom in the Output Module, toggle the menu next to format and select MPG2-DVD.
    Hope this helps.
  • Frank Sievert
    July 5, 2007 at 5:06 am
    and – this is maybe you are on a mac?
  • Gianni75
    July 5, 2007 at 10:05 am
    Hi Dave,
    many thanks for your reassure. I’ve already try it exporting in AVI (DV format), import in Premiere and then use the Premiere’s MPEG module: good results!!
    Bye
    Gianni
