Activity › Forums › Apple Final Cut Pro Legacy › mpg2 darker than timeline
  • mpg2 darker than timeline
    Posted by Ken Nemetchek on June 7, 2006 at 7:37 pm
    Okay, so what’s the deal?
    I’ve been trying to get fcp to export via compressor an mpg2 file that is not darker than my timeline. I thought I had read here that the latest version of compressor fixed this issue (I’m using fcp 5.1.1 and compressor 2.1), but things export as dark as ever.
    Is there something I should be doing different, or is this problem best solved by a new piece of hardware? Please tell me I don’t have to spend more money.
    Ken Nemetchek
    Alberta Visual Communications
    Simon Carlson-thies replied 20 years, 3 months ago 5 Members · 6 Replies
  • Simon Carlson-thies
    June 7, 2006 at 7:48 pm
    I haven’t run into this problem, but you could try a workaround, by exporting to some other codec like a lossless format, like animation codec, or no compression, and then recompress to mpg2… in QT Pro or in compressor…
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • John Sellman
    June 7, 2006 at 8:12 pm
    I’ve had this happen and ended up adjusting the brightness within Compressor before I export. This worked fine although a pain in the ass.
  • Chris Poisson
    June 7, 2006 at 8:47 pm
    This seems to be a problem with every encoder I’ve tried with the possible exception of Bitvice. Compressor, Squeeze and Compression Master all seem to want to lower the gamma and increase the chroma and/or saturation. Yes it’s a pain, especially since you can’t see the filter results til you burn the disc, but I have got some great results doing this.
    Have a wonderful day.
  • Don Greening
    June 8, 2006 at 3:37 pm
    [Chris Poisson] “Compressor, Squeeze and Compression Master all seem to want to lower the gamma and increase the chroma and/or saturation.”
    You might find the info at the following link interesting:
    https://www.visiontracks.com/compressortests/
    – Don
  • Chris Poisson
    June 8, 2006 at 6:09 pm
    Don,
    Very interesting, similar to my experience.
    June 9, 2006 at 6:41 pm
    you should be able to view the file before you burn.. QT Pro with MPEG2 codec…
    Simon Carlson-Thies
