Activity Forums Compression Techniques Mpg won’t play in quicktime or mpeg streamclip or compressor
  • Mpg won’t play in quicktime or mpeg streamclip or compressor
    Posted by Rachel Pandza on February 3, 2011 at 5:57 pm
    My Video File won’t play in mpeg streamclip and quicktime( which i have the latest versions) it just appears white with no sound. But it will play fine in VLC player fine and in compressor just freezes when I load it. I need to get it to play in quicktime, or does anyone who a good compression software I can buy to convert it? or what the problem is?
    Specs:
    General / Container Stream #1
    Total Video Streams for this File……………..1
    Total Audio Streams for this File……………..1
    Video Codecs Used……………………………MPEG-2 Video
    Audio Codecs Used……………………………PCM
    File Format…………………………………MPEG-PS
    Play Time…………………………………..2h 46mn
    Total File Size……………………………..62.3 GiB
    Total Stream BitRate…………………………53.7 Mbps
    Video Stream #1
    Codec (Human Name)…………………………..MPEG Video
    Codec Profile……………………………….4:2:2@High
    Frame Width…………………………………1 920 pixels
    Frame Height………………………………..1 080 pixels
    Frame Rate………………………………….23.976 fps
    Total Frames………………………………..238819
    Display Aspect Ratio…………………………16:9
    Scan Type…………………………………..Progressive
    Color Space…………………………………YUV
    QF (like Gordian Knot)……………………….1.006
    Codec Settings (Matrix)………………………Default
    Video Stream Length………………………….2h 46mn 0s 742ms
    Video Stream BitRate…………………………50.0 Mbps
    Video Stream BitRate Mode…………………….CBR
    Bit Depth…………………………………..8 bits
    Video Stream Size……………………………59.3 GiB (95%)
    Audio Stream #1
    Codec………………………………………PCM
    Audio Stream Length………………………….2h 46mn 0s 741ms
    Audio Stream BitRate…………………………1 536 Kbps
    Audio Stream BitRate Mode…………………….CBR
    Number of Audio Channels……………………..2
    Audio Channel’s Positions…………………….Front: L R
    Sampling Rate……………………………….48.0 KHz
    Bit Depth…………………………………..16 bits
    Audio Stream Delay…………………………..945ms
    Audio Stream Size……………………………1.78 GiB (3%)
    Craig Seeman replied 15 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Craig Seeman
    February 3, 2011 at 6:09 pm
    What you’re seeing is typical. Quicktime is not good at playing MPEG2 Program Streams. Your specs look like they’re geared towards broadcast delivery as a mezzanine file given the specs and data rate.
    There’s no reason to expect or even have as a goal for this to play in Quicktime.
    If this is a source file then encode to one of Compressor’s Quicktime 7 presets or create your own.
    If Compressor can’t handle it as a source I’d recommend trying Telestream Episode.
  • Rachel Pandza
    February 3, 2011 at 6:32 pm
    Ok thanks, is this the only program that will encode these? or are there any free or cheaperones?
    Will that quicktime plug-in https://store.apple.com/us/product/D2187Z/A be able to at least play it in quicktime?
  • Craig Seeman
    February 3, 2011 at 6:58 pm
    Try MPEGStreamclip. It doesn’t have to play it, just encode it to H.264. As long as you can see the video it’ll work.
  • Olin Padilla
    February 3, 2011 at 8:37 pm
    MPEG Streamclip probably won’t allow you to transcode without purchasing the MPEG-2 Playback Component. You can try exporting from VLC using the streaming/exporting wizard, although it’s kind of an annoying and limited process.
  • Craig Seeman
    February 3, 2011 at 10:07 pm
    If she has Compressor she might have the playback component as it was included with FCS (although I’m not sure about the current version). There are some MPEG2 Program Stream encodes that Quicktime won’t playback even with the component though.
    Alas this is one good reason why I use Episode.
    You might try this since it’s based on ffmpeg. It’s not free but it’s certainly inexpensive and getting good reviews.
    https://www.macupdate.com/app/mac/35846/iffmpeg
  • Olin Padilla
    February 3, 2011 at 10:31 pm
    By the way, the MPEG-2 Playback Component is only $20. I don’t actually have it, so I can’t really vouch for it.
    (For broadcast work I use Episode with broadcast presets provided by the client).
  • Craig Seeman
    February 3, 2011 at 10:37 pm
    I have the MPEG2 component from a previous FCS install. It didn’t seem to come with FCS3 though so I just moved it in from an older computer. I noticed that Rachel’s file is 4:2:2 and that might be the issue. I think the component only plays 4:2:0.
    If I encode MPEG2 4:2:2 Program Stream for DG Fastchannel in Episode, Quicktime will not show the video even though I know I have the component installed.
